跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
Is the iFixit adhesive remover just isopropyl alcohol?
I am thinking about doing a keyboard replacement for my MacBook Pro but the battery must be pried off first. Instead of forcing it off, I found the adhesive remover in the store, but I’m hesitant to spend $33 for a solution that is similar to alcohol.
Has anything else worked for anyone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
已选择的解决方案
Hi @davchun
Watch the provided link and at 8 Second, pause,
https://www.youtube.com/watch?v=8krNjKEs...
It mentions contain Acetone
, etc almond fragrance....
这个答案有帮助吗?
得分 8
2条评论:
Check out aldon-chem website and search for sds, or google “aldon chem sds”. Chemical name “AA-0051”. The sds says it’s 99.8% acetone, 0.1% Cherry Almond Fragrance and 0.1% FD&C Blue #1 (C.I. No. 42090). It’s all public information.
完成的
添加一条评论
这个答案有帮助吗?
得分 6
1条评论:
添加一条评论
I went to Walgreens and get 100% acetone nail polish remover. It works
这个答案有帮助吗?
得分 3
添加一条评论
I started using pure methanol a couple of years before iFixit found a solution.
这个答案有帮助吗?
得分 2
添加一条评论
I am thinking of replacing my macbook pro battery. Hesitant to buy an adhesive remover. But wouldn’t the acetone/nail polish remover damage or erode the old battery and causing problems?? I mean the old battery should be pretty fragile, I suppose..
这个答案有帮助吗?
得分 0
2条评论:
[image|1948870]
yeah just go buy acetone lol
完成的
Acetone might affect the plastic covering but the actual battery cells are encased in metal. Acetone should be ok but I'd avoid nitric acid.
I replaced a battery just now and tried isopropyl alcohol (100%) on one side and acetone on the other side. I didn't find a lot of difference in how they removed the glue and I can say that both solvents struggled to dissolve it.
完成的
添加一条评论
Is it just Concentrated Windshield Washer Solvent with Ammonia?
这个答案有帮助吗?
得分 -1
1条评论:
google aldon chem sds and search for AA0051. it's a mix of acetone, fragrance and blue dye.
完成的
添加一条评论
添加你的答案
David Chun 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 34
过去 30 天: 127
总计 15,570
