跳转到主内容
加入维修社区 - 创建账户
Jensen JTA-230 是一款于 2004 年发布的 3 速立体声唱片机。
Turntable not powering ,while connected
Have Purchased Jensen JTA 230, it was working perfectly with an voltage adapter step down 220V (since am using in INDIA ,where power supply is 220V).
It was working properly for 1 year , but suddenly it stopped working . Not able to know the reason , as the adapter is working properly (checked in the local store) but turn table is not working .
Please help here with some input .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Hopefully no one connected the turntable to the 220VAC power without an adapter which lowers the voltage to 120VAC
You may have to open the turntable and inspect it for any obvious damage, such as burnt out components, blown fuse etc.
Here’s a link to the ifixit Jensen JTA-230 guide which may be of some help in dis-assembling the turntable.
If there is nothing obvious, you may have to start doing static (power totally disconnected from the turntable) point to point testing of the power circuit using an Ohmmeter (function in a DMM - digital multimeter) to find the problem. Start where the power cord connects to the circuit board.
If you do see something and you’re not quite sure, take some close up pictures and post back here and hopefully there will be further help.
Here’s how to do this. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
abhishek 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 24
总计 646
