跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
My iPhone 3G is not charging..?
I took my iPhone with me to India on my vacation. The voltage is 230V over there. I charged it couple of times there using wall charger. Then, while i was charging through the USB which was hooked up to the PC, i got an error message saying "this accessory is not compatible with this device" and it simply stopped charging. Now that i am back in the USA, i tried to charge the phone but it won't work. Can anyone help me to fix it. All suggestions are appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Nikhil, just to make sure this is not going to become a red herring, when you charged it in India, what adapter did you use? Did you use one that is from there or did you use the one that you got with your phone. I am not sure if it would even fit, but just wondering?
完成的
添加一条评论
2个答案
已选择的解决方案
usually this message pops up when the dock connector pins are dirty or damaged. try cleaning them with a brush to remove any dirt/pocket fluff etc. you can also try compressed air etc. then try again with the charger. If there is no change (ie message pops up occassionally) and the phone still charges and it is recognised by itunes then you can change the dock connector using the guide to the right (link is under the photo of the phone)
这个答案有帮助吗?
得分 4
3条评论:
try replacing the dock connector
完成的
yep, just like pollytintop said...;-) good answer
完成的
I don't get the message anymore. Now when I connect the phone to the charger nothing happens. The phone just stays dead. So, I will change the dock connector and ll let you guys know what happens..!Thank you for all the help.
完成的
添加一条评论
see this blog...
http://willy.boerland.com/myblog/iphone_...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nikhil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,850
