跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for Panasonic's Viera line of televisions.
TV won't turn on - red light flashes 14 times, pause, then 14 more
Panasonic Viera TC-P42X3 - I hear a click when I plug the tv into the wall socket. Then when I push the ON button on the TV I hear another click but the TV does not come on. If I hold the ON button down the red light on the front of the TV flashes 14 times, pauses then flashes another 14 times. PLease help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@denisejaco most common fault for this on your model is either a bad SN or SS board due to bad (lost)ground issues. I suggest that you start with those (replace both to prevent damage one if you do not replace the other one as well).Less common fault is a bad P-board.
You can of course always post some images of your boards etc. so that we can see what you see and possibly provide more answers. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 3
1条评论:
Hi, I have Panasonic Viera tc-p46x3 by 12 blinks code, How can i fix it? Also if i should change the SS or SN Board regarding to your answer, How can I have this 2 board? Thank you
完成的
添加一条评论
添加你的答案
Denise 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 100
