跳转到主内容
加入维修社区 - 创建账户
2017 年 9 月 22 日发布。型号 A1864、A1897。有 GSM 或 CDMA 版本可选,存储空间为 64 GB 或 256 GB,颜色有金色、银色和深空灰色。
Overheating and drainage fast.
Hello,
i have a question.
I run an repair shop and i repaired like dozens of phones.
i recently refurbished my own iphone 8 plus device to make it look new.. but now my phone is overheating entirly but at the power button it is even warmer.
the phone also lose 1% every minute when using it.
-housing replaced
  • original battery
  • Oem screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I got the same problem :(
Have you fixed it?
由完成的
添加一条评论
2个答案
最有帮助的答案
Bad Tristar chip on the motherboard. Microsoldering required to repair it.
这个答案有帮助吗?
得分 1
2条评论:
Checked chip.
Its fine.
I notice when i am using the phone with on spotify and when using sound true top speaker the phone is getting hot.
Any solutions for that?
由完成的
So,
This is the place where it heats up.
https://ibb.co/8Y5zDpG
On the front and at the power button it heats. The most i feels like 40c back site is little warm.
Rest of the phone is not as warm as the top
由完成的
添加一条评论
Did you try a new battery? Also go into your settings go to battery and than battery health. If its below 82%, I recommend a new battery anyways.
这个答案有帮助吗?
得分 0
2条评论:
Changed housing,
Changed battery
Changed screen.
Everything works normal...
Just special apps like spotify , gaming its getting hotter as usual... and then the battery drains way faster.. like half of the time as before
I am running ios 12.2. i refurbished this one and i put my back up on this phone and had to update it. So i dont know if it was befoee the update aswell.. thats the problem.
Is it possible that it could be?
-faulty screen
-proximity sensor?
- copy power flex
- copy dock connector
由完成的
Maybe just backup your phone and then do a DFU restore to see if that fixes it.
由完成的
添加一条评论
添加你的答案
glennjacobs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 855
