跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
774 个问题 查看全部
Replaced battery now I cannot log in
SO, I replaced a bulging battery yesterday with an Ifixit replacement. It worked great after the replacement, ran the battery all the way down to help condition it and calibrate. After the macbook shut down I put it on the charger and it sat amber for about 4-5 hours. Something seemed off, so I booted it up to look at it and there is a triangle with an exclamation point in the battery. So I reset the SMC, no luck, next I reset the NVRAM, no luck. Ran a diag, says battery needs serviced, the weird thing is I cannot login at all, it gets about 20-25% of the way through the login screen then it reboots and I’m back to square one. I have tried to restart and do ye ol’ cmd+r, nothing, just boot loops. Tried safe boot, no luck. Anyone have any ideas, my guess is a $@$* battery, just weird how it worked fine on the battery after install but when it powered down it seemed to $@$* the bed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Batteries are a painful topic, if you do a search on the forum questions you’ll see there’s someone having troubles every day, especially with aftermarket batteries. Your Mac runs off charger only too, thus you have an easy testing tool available, just unplug the battery from the board and see what happens. If it’s a battery issue the Mac will boot on its own and allow normal operations as soon as you connect the magsafe charger, in which case just ask for a battery replacement. If the issue is still there..well, let’s hope it’s not there to start with ;)
这个答案有帮助吗?
得分 3
4条评论:
I have the same issue, unfortunately this solution didn´t help.
The loading bar after trying to login was constantly getting up to 1/20 before restarting - then I reseted NVRAM and now it goes to 1/5 and then restarts :D.. It´s the same when the battery is unplugged.
I followed this tutorial - MacBook Pro(15英寸,带有Retina显示屏,2015年中旬)电池更换 - do you know where the issue might lie? Is it most likely caused by permanent damage to something or do you think there is still a chance of making it work again?
Thank you very much,
Jan
完成的
@Jan Kršňák A number of issues may give the same outcome, thus it's hard to diagnose something like what you're experiencing..it may be software with a corrupted system, a faulty SSD or even a logic board problem. Try these hints to start with, so as to to try narrow down the issue: https://support.apple.com/guide/mac-help...
Since this was a battery related question that was already closed, please do create a new one in case you need further help :)
完成的
@arbaman great, thank you very much for your help, I will check it out
完成的
@Jan Kršňák - If you can get your system running install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片 that way we can see what's happening with your battery and charger logic if it's not a software issue.
完成的
添加一条评论
添加你的答案
Nicholas Bates 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 626
