跳转到主内容
加入维修社区 - 创建账户
ThinkPad X200 发布于 2008 年。它采用了来自 X300 的新技术,包括可选的固态硬盘 (SSD)、可选的内置摄像头、12.1 英寸宽屏显示屏、可选的 3G WWAN、可延长运行时间至 9.8 小时的全新 9 芯电池、仅 1.34 kg(2.95 磅)的重量,以及主频最高达 2.66 GHz 的 Intel Core 2 Duo 处理器。
Ethernet not detecting network
Hi,
Swapped my HDD for an SSD and installed a fresh copy of Win 10.
Naturally I had some driver issues, but try as I might, My LAN connection will state “Unidentified Network” and will not connect to the internet.
Wifi is working well and connects to the internet.
Tried the driver on: https://support.lenovo.com/il/en/downloa...
Adapter is detected as “Intel 82567LM Gigabit Network”
Laptop full model is: 7454-2HU
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
9条评论:
Hi @goom
Had you tried updating the laptop BIOS?
Had you tried using another LAN cable?
Had you tried connecting to another known working LAN port?
由完成的
Hi @goom ,
What is the status of the LAN adapter in Device Manager?
Go to Device Manager (right click Windows Start button, left side of Taskbar, find Device Manager link) > Network Adapters > right click LAN adapter entry > Properties > General Tab > Device Status.
Have you tried using the Troubleshooting program in Win 10?
Go to Control panel (click on Windows Start button left side of Taskbar) type Control Panel in search box > select Control Panel desktop app that appears in pop up window > Troubleshooting > Network and Internet > Connect to the internet and follow the prompts
由完成的
Will try BIOS.
Have tried different cables and routers.
LAN device is working and up to date.
Troubleshooter can't understand why I'm not getting an IP.
由完成的
Did you check the antenna wires to the wireless adapter? The connectors tend to be easy to take off but sometimes very hard to connect.
由完成的
Wirless adapter works flawlessly.
由完成的
显示更多的4条评论
添加一条评论
1个答案
I suspect the wrong driver might be installed. I’d suggest finding the hardware ID of the wireless card and searching google with it to make sure you have the correct model of your wireless card.
To find the Hardware ID go to device manager—>device properties—> details tab—> and then choose “hardware id” from the drop down list. Copy one of the strings listed and paste it into google and see what comes up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Goom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 1,830
