跳转到主内容
Guides and support for various television (TV) brands and styles.
9064 个问题 查看全部
Screen goes black then I turn off then works then back to black
My tv went black the other day I turned it off by the remote then back on it was working then next day happened again done the same worked for a day and now today when I turn it back on it works for a few hours then goes black with the sound still on happened a couple times already I unplugged it then plugged back in worked for few hours then went black it’s going back and forth is this happened to anyone need help
its a jvc smart tv
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@lprince
this sounds like your backlight failing. Check your power board for any obviously damaged components. When the screen turns dark, shine a flashlight at an angle against the screen. See if you can still make out any silhouettes etc. If so it’s your backlight. If not then there is the possibility this is either main or power board related. You will have to let us know what exact model your TV is. Once you remove the back from your TV post some good pictures of your boards with your question. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
添加一条评论
Hi @lprince,
Try doing this to see if you get a picture:
  1. Hold the Volume Down and Menu buttons
  2. While holding them, press the Power button then release the Power button only
  3. Wait five seconds then release of the Volume Down and Menu buttons
  4. Wait for approximately 30 seconds
Do you get a picture?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prince94 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 110
