跳转到主内容
加入维修社区 - 创建账户
2014 年发布的一款 14 英寸商务笔记本电脑。市面上最早的 Haswell 架构商务笔记本之一。
Wiped SSD but Cannot Boot Anymore
Hi, I performed a successful ATA Secure Erase on my WD SSD (comes installed). This went fine. Upon going to turn computer back on after shutting it down, it only opens to a message:
Dell Security Manager
Hard Drive #######, the system internal HDD-0, is protected by a password authentication system. You cannot access data on this hard drive without the correct password. Please type in thehard drve password.
I put in the password and I get:
No bootable devices found
Press F1 key to retry boot.
Press F2 key for setup utility.
Press F5 key to run onboard dignostics.
I don't need to keep any data on the computer, I'm actually trying to get back in to do a factory reset, so if there's a way to do that without any of this that works also. The computer was running only on Ubuntu 18.04.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You need to reinstall the operating system. If you have another computer available to use, use that to create USB installation media for ubuntu and then you’ll be able to boot ubuntu off the SSD again.
You can download ubuntu here:
https://www.ubuntu.com/download
Use Rufus to burn the downloaded ubuntu ISO onto a flash drive:
https://rufus.ie/
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Please help 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 715
