跳转到主内容
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53 个问题 查看全部
Where is the fuseable link for the ignition
where is the fuseable link between the battery and the ignition switch
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I know that there is a 100 amp fuse that is bolted in place. There are access covers on the side of the fuse block that allow you to remove the 2 8mm-headed bolts holding it in place. Here is a Video that will show you the location as well as how to change it.
So the main fuse is under your hood in the fuse block. I attached a few pictures so you know what to look for. The red circle is the main fuse the yellow you can ignore since that is not your problem. They are for the EGI. Also attached an image for all of your fuses. The manual says to remove the fuse disconnect the negative battery cable.
Remove the main fuse block cover, remove the main fuse block mounting nuts. Remove the MAIN fuse mounting bolt to remove the fuse.
Hope this helps with your problem. Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
It should be under the hood, in the fuse box. It isnt a small fuse like you would change normally, it is a larger 50A one probably.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
timothyguy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 4,512
