跳转到主内容
加入维修社区 - 创建账户
2016 年 9 月发布。 型号为 SM-G610。
Why is my back button not working
What causes some keys not to work sometimes? I discovered the return/back button on my phone wont respond to touch often times. This is frustrating because it makes using an app that requires a return function difficult.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
The same with my phone return button didn't work but when I tried to reset it works it features not the factory reset it work for several minutes only, then not working again, seems there's time elapse program to lock. I tried all options even the factory reset. The same happened working for several minutes only.
完成的
Can anybody suggest to solve this problem without going to any phone tech?
完成的
لقد سقط هاتفي مرات كثيرا علئ الارض
完成的
添加一条评论
3个答案
最有帮助的答案
Do you have a screen protector on the phone? If you do it could possibly just be a case of a bad cheap screen protector. If not it could be an actual issue with the buttons themselves. Or it could just be phone lag if they eventually do respond or if the phone freezes when you press them.
Hope this
这个答案有帮助吗?
得分 1
添加一条评论
I had this problam too, when i opened the phone there was a little water damage.
Are you sure it does not have any water damage…
这个答案有帮助吗?
得分 0
添加一条评论
My back button don't work at all
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chinwe U-O 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 27
总计 6,360
