跳转到主内容
加入维修社区 - 创建账户
Kocaso 安卓操作系统平板电脑的维修指南与支持。
The process com.android system has stopped
It has two error messages. The one above and it also says something about google gapps. System will not reset
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
My screen will not even go to the home screen. And I can not get it to reset
由完成的 分享
添加一条评论
2个答案
In my experience this typically happens when there are more apps/processes than the device can handle running all at the same time. It happens on my Lenovo tablet and the cheaper Android device I bought recently. Sometimes it only affects certain processes when I'm playing certain games or if there are too many things all open and running in the background. It may help to go into apps in settings and just go down the list and force close any games, apps you aren't using and see if this helps. Unfortunately I find it's only a temporary band-aid solution as certain tasks just need more power/memory to function properly and less expensive devices sometimes just fall below the requirements.
这个答案有帮助吗?
得分 0
添加一条评论
Where are you seeing those messages pop up and was it having any other symptoms before you started seeing the messages?
Try these steps:
After your tablet turned off, hold Volume Up + Power buttons at the same time for about 5-10 seconds. You will see options. Use Volume down button to scroll and select Wipe data / Factory Reset.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Taneshia Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 503
