跳转到主内容
加入维修社区 - 创建账户
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Battery won't charge
Hi ifixit community, hoping you can help me on this one - I've been struggling to get this thing working for a long time.
I replaced a water-damaged Macbook (mid-2008) logic board and it now works, however it doesn't work properly when the battery is plugged in.
I figured it just needed a new battery but even the brand new battery does not charge in the Macbook nor does the Macbook function properly with it plugged in. With the battery in the screen doesn't seem to display correctly.
Remember the Macbook works fine off the wall charger with no battery installed.
I tried replacing the battery connector hoping that would fix the problem - it did not.
What component still needs to be replaced to get this to work? Do I perhaps need to replace the inverter? I think I heard something about that in the Macbook troubleshooting guide.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
my battery on my RCA tablet wont charge
完成的
I bought this tablet 3/2015 it's still under warranty I need to send back to the factory to have the battery replaced, I'm having a difficult time trying to find out where to send it
完成的
添加一条评论
2个答案
已选择的解决方案
The next logical step would be to replace the MagSafe board. These corrode quickly. Here's how to do it: MacBook Core 2 Duo Magsafe Board Replacement
Here's the part: MacBook MagSafe DC-In Board
Replace a broken or damaged MagSafe DC-in board for your MacBook with this part. This part connects the wall adapter power to the logic board.图片
产品
$19.99
这个答案有帮助吗?
得分 2
添加一条评论
The inverter has to do with the display, so it'd probably be something like the DC-in component.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RZephyr07 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 3,903
