跳转到主内容
加入维修社区 - 创建账户
The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
turns over but will not fire
my car has gas in it does not stall or hesitate was running just fine until a couple days ago it died while idling started right back up but when i parked it when back out a while later it wont start turns over but wont fire
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
2002 grand prix.replaced fuel pump.it kicks in but wont start and backfires?any help?
完成的
If there is old gasoline in the tank it may have turned into water. Try adding some dry gas to the tank.
完成的
添加一条评论
2个答案
Check for spark at plug wire, if no spark check ignition fuse if ok check coil pack if ok you may have a broken timing belt
这个答案有帮助吗?
得分 0
添加一条评论
I had to replace the fuel pump in mine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mkazee81 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 30
总计 2,703
