跳转到主内容
加入维修社区 - 创建账户
Apple Wireless Keyboard 的维修指南与支持。无线连接并操控你的 Apple 电脑。
Key board won't use battery.
When I put in new batteries. The key board won’t power up or get energy from the batteries. The work around I use is to ball up a small piece of aluminum foil and drop it inside followed by the batteries. Only then will it charge up. How can I fix that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
were the wrong size batteries fitted at a previous date? or did a battery leak in the battery compartment?
it sounds like the metal spring at the bottom of the compartment isn’t making good contact with the battery, so it may be corroded or flattened too much.
You can remove the inner frame on these to inspect and clean the contacts, but it’ll likely be one of those two scenarios.
I hope this helps
苹果无线键盘(A1255)拆卸
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
jigsb9 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 14
总计 340
