跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for Kenmore washing machines.
Kenmore washer error code
Error code OL for a kemore washer model # 27052600
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
1个答案
已选择的解决方案
sharrybaseball The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this could indicate either a drag on the drive system or the control board is failing. Empty the washer and spin the basket to check if it rotates freely. If it does not, then something may be caught between the spin basket and the outer tub which could give you an OL code. Also check for any obstruction underneath the washer by the motor that could be interfering with the motor. If you do not find any problems with the spin basket, then there could be a problem with the tub bearing, or worst with the control board or the motor.
Going by your number your washer is a 110.27052600 Kenmore Elite Oasis
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
sharrybaseball 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 79
