跳转到主内容
加入维修社区 - 创建账户
SanDisk Cruzer Glide 是一款带有可伸缩 USB 插头的 U 盘。它有多种存储容量可选,所有型号均采用黑红配色的塑料外壳。
Is this Flash Drive fixable?
I accidentally droped the laptop that this was plugged in to… the cover for it split and when we went to plug it back in, it wasn’t showing up on the computer. I feel like this can be fixed easily since the connection to the motherboard is still intact… It’s just not showing up on the laptop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It probably cant be fixed unless you go to a professional so unless you have information you need on it then give up. Or if your lucky you can play around with it and it will work. Good luck
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
I agree that it probably can be fixed but easily…no. It’s hard to say from the pictures but when a USB drive is physically damaged, it usually means some traces on the circuit board are damaged. This can be fixed but it requires micro-soldering and that makes any DIY repair unlikely.
Here’s an example of the type of damage I am referring to.
If you value the data on the drive, you could send your USB Drive to a micro-soldering repair specialist.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Brett W 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 969
