跳转到主内容
加入维修社区 - 创建账户
Lenovo C560 发布于 2014 年,是一款配备 23 英寸屏幕并可选配触摸屏支持的一体机。
Computer Wont Boot Up
I have a Lenovo c560 all in one and recently I had been running into some trouble regarding its booting. Sometimes it will boot, and sometimes it wouldn’t. Eventually it stopped booting completely and would just be a black screen with a feint clicking sound so I decided to do some research, and saw online that changing the hard drive cable would work so I tried this and it worked initially but then wouldn’t work again. Can someone please help as I need for work. Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I dont know how to use the usb if the pc wont load. Is there a key I press on startup because nothing shows on the screen at all at any point
由完成的 分享
Press F2/10/12 ESC or DEL imediately after you turn on the pc. It's either of those which will get you in the BIOS or bootmenu.
由完成的 分享
when starting it would go on but show automatic repair then lead me to the advanced options
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
If the computer won’t boot and there is a faint clicking sound, then your HDD hard drive may be failing. HDD hard drives make a clicking sound when they are about to permanently stop working. You may have to get a new hard drive soon.
If there is data on your hard drive that needs to be saved, please save it immediately. If you cannot salvage the data, perhaps a technician can do it for you.
这个答案有帮助吗?
得分 3
添加一条评论
Might be your HDD dying.
  • Try resetting the BIOS to default settings and see if that works.
  • Get a Windows 10 installation usb stick and run startup repair
  • Install Windows on a fresh HDD and see if it boots from it
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anthony Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 1,803
