跳转到主内容
加入维修社区 - 创建账户
Sega Game Gear 便携式游戏机于 1991 年发布,旨在与 Nintendo Game Boy 竞争。
Capacitor problem, choosing capacitor
Good Day!!!
The board is vr1 version of sega game gear. I can't find a 33uf, 0.47uf, 4.7uf, 22uf, 68uf capacitor can I use higher value? Thanks in advance!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This is hit or miss, 1206 smd . <1uf use 1uf smd, <10uf use the 10uf, <100uf use 1210 SMD 100 uf
由完成的
添加一条评论
2个答案
已选择的解决方案
Hi @faustrepair ,
You cannot use higher values than what the circuit design requires. It will change the characteristics of how the circuit operates (if it still will operate that is) if you do.
The type and values of the capacitors were selected for a reason when the circuit was designed
Did you check on places such as this?
Also you’ll have to know a bit more that just the capacitance value. Such as working voltage, what type of capacitor, physical size etc.
这个答案有帮助吗?
得分 2
添加一条评论
This is hit or miss, 1206 smd . <1uf use 1uf smd, <10uf use the 10uf, <100uf use 1210 SMD 100 uf. Few to many years later on this👍🏼
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Faust Tan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 26
总计 642
