跳转到主内容
This guide page will help you diagnose problems with the Toshiba Satellite C55-B5200.
9 个问题 查看全部
Where is the motherboard battery?
BIOS time and date is resetting if I don't have the laptop battery in and if I don't have the laptop plugged in. In order to stop that I'll trying to change the motherboard battery. However I do not see it when I take the bottom cover off. I'll trying to find its location.
Manufacturer: Toshiba
Model: C55-B5299
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
This laptop model does not have a CMOS battery. On the motherboard you will see a spot that one should be located. If you disconnect or let your main battery run dead you will have to re-enter your date and time settings when booting your laptop for the first time.
这个答案有帮助吗?
得分 4
5条评论:
@itsd_btech What is the solution to this problem then? My battery doesn't charge and my laptop only runs while plugged in, and needs bios time update each time I plug into a new socket.
完成的
I would recommend replacing the battery with an OEM quality battery. Either your battery is not recognized by the laptop or is failing and needs replaced.
完成的
buy a good replacement battery (about $20 USD, put in new battery and charge fully in the off position. Re-enter current date n time in BIOS and all should be well
完成的
Be sure to train the new battery! When they first charge they may only last 30 min to 1 hr. But after draining to about 10% or so and fully charging to 100% you will get way longer life. I train new batteries three times for best results, although the most benefit occurs after the first full cycle.
完成的
i replaced the main battery, it has no rtc battery, pressed the on button, the on button stays lit for 5 seconds then turns off, the dammned thing wont turn on !!!
完成的
添加一条评论
Hi Alx,
I would guess that it may be under this cover.
这个答案有帮助吗?
得分 3
8条评论:
@arthurshi - Authur, You must be good with Finding Waldo puzzles ;-}
完成的
It was one of my favorite childhood pastimes :)
完成的
This model does not have a CMOS battery on the motherboard. The spot you are showing in the picture looks like a potential placement. If you take the motherboard out you will see underneath there is no battery.
完成的
I'm having the same issue. I let my battery die by watching a movie that I fell asleep to. Now all I get is the Toshiba splash screen. No bios, nothing. There is no battery. I looked.
完成的
Does anyone know a fix for this?
完成的
显示更多的3条评论
添加一条评论
This model do not have any CMOS battery, …ignore the shape of battery on the mobo, there is no battery on the underside. First time I ever encountered this in my 17 years dealing with computers. It's very unusual but it's true
这个答案有帮助吗?
得分 1
2条评论:
I have a Toshiba Satellite L55-B5267. I am also unable to locate a battery on the board. I am getting prompted for a BIOS password. How do I clear the password. No battery so I am unable to locate the correct jumper location on the board.
完成的
Mine did this I replaced the hard drive and reinstalled windows and boom fixed
完成的
添加一条评论
I had the same problem. Just replace the battery, fully charge the new battery, set your date n time and you are all good to go.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alx V 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 30
过去 30 天: 142
总计 15,176
