跳转到主内容
问题已关闭
My cpu fan is dead
My cpu fan seems to be dead. How do i replace it? thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
xop here is the Service manual service manual for your computer model. It is a HTML version but can be downloaded. It will show you exactly what to do. Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
Parts-People.com is a great resource for finding/buying Dell laptop parts and they also have guides on how to fix it yourself.
You're going to need one of the two fan models on the page below. Check which one is already in your system and then purchase the appropriate one.
http://www.parts-people.com/index.php?ac...
Then use this guide on how to replace it.
http://blog.parts-people.com/2011/04/13/...
Hope that helps!
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
You can buy a CPU fan from eBay and you tube the tutorial to replace it on board. However I would suggest you to take your replacement fan to a local technician shop and have it replaced as logic boards are little delicate and doing it in a wrong way can cause a permanent damage to your processor.
Good Luck.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 2,248
