跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
Mattes Display gegen Glossy Display tauschen / Exchange Matte Display
Hi,
kann ich bei einem MacBook Pro aus Mitte 2009 das matte Display-Assembly im Falle eines Defekts gegen ein Glossy Display aus einem MacBook auch aus Mitte 2009 tauschen?
Danke im Voraus für die Antworten!
English version:
Hi,
can I exchange the display-assembly of a MacBook Pro Mid 2009 Matte against a glossy display-assembly of a MacBook Pro Mid 2009 in case of a defect?
Thanks in advance for answers!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Not really, although most parts are just the same, the matte version has the wifi/bluetooth board in the top case and that makes the replacement partially incompatible. If you would be happy without any wireless connection it shouldn’t be a problem instead.
这个答案有帮助吗?
得分 3
2条评论:
Thanks for your reply!
Can I install WiFi/Bluetooth on the board or are the Matte and Glossy MacBooks of Mid 2009 are using different internals?
完成的
@lorenzm It's quite some time since I had the chance to work on a matte 2009 Macbook Pro and I believe I don't have around any spares left to take a look unfortunately. Matte and glossy do have different internals..as I said the Matte has wifi/Bt board in topcase, whereas the glossy has them in the assembly. I honestly couldn't tell if some mod would be possible, I am sorry I can't be of further help.
完成的
添加一条评论
添加你的答案
Lorenz M. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 41
