跳转到主内容
加入维修社区 - 创建账户
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
looking for parts schematic
looking for parts schematic, specifically for the white dvd drive protection system. Just changed the drive assy and laser lens and voila I found a single white piece on the floor. I have gone through all the repair guides I have found, both here and throughout the web and haven't been able to find anything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Clint, the same thing just happened to me, if I post a pic of the part, would you remember well enough to recognize if it was the same part?
完成的
Andrew, go ahead and post the picture and I will definately try to help you out. Clint
完成的
添加一条评论
2个答案
已选择的解决方案
Clint Birdsong it would be better if you have a picture or anything a bit more descriptive. I wonder if this is the part you are thinking off. ( see attached image :-) That is the white slide on the side of the drive that covers the gears. Good Luck and I hope this works.
这个答案有帮助吗?
得分 2
1条评论:
No that isn't the area. I was looking at the unit a little closer and I think I found it on the reverse side across from this linkage that holds the drive brace down.
完成的
添加一条评论
Andrew, go ahead and post and I'll give it a go.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Clint Birdsong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,458
