跳转到主内容
加入维修社区 - 创建账户
Sony SRS-X5 便携式扬声器于 2014 年发布。它以高音质和可靠性而闻名。
Where can we find replacement speakers?
I’m looking to replace a blown speaker but not having any luck finding replacement parts for this. Do you know of any resources or parts numbers for this product?
Thanks
- j
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @jdiddy
Can’t really help regarding parts but here’s some information that may be of some help.
Here’s a link to the ifixit Sony SRS-X5 guide.
Here’s the Sony part number for the speaker 151026B1510268
If you search online using the part number only, you’ll get results for suppliers. Unfortunately all of the ones I found say “currently out of stock”. You may have better luck.
You may be able to source a compatible replacement speaker by checking what information is printed on the speaker driver.
There should be the speaker’s impedance value in Ohms (see image for Ohms symbol) and its’ power rating in Watts (W).
If you use this information coupled with the diameter of the speaker (remove it from its mount in the case and measure it) you may be able to find one to suit, i.e. search for (insert diameter) 4 Ohm (insert W) speaker. An example of your search term could be 2.5” 4 Ohm 5W speaker. I have no idea if the example figures mentioned are correct for your particular speaker, it is just an example ;-)
这个答案有帮助吗?
得分 3
1条评论:
@jayeff - great info and greatly appreciated! Once I get in there I will know better as to what to look for but thank you for the tips. This definitely helps! - Cheers!
由完成的 分享
添加一条评论
添加你的答案
Jason 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 907
