I need a new elbow clip?
The clip that attaches the elbow to the body of the vacuum and the hose is broken off. I Need a new one and can not find it in the parts lists. Whats it called and am I able to buy a new one?
Same happened to me and I wound up using two zip ties to secure it in place. Works just like normal.
这个答案有帮助吗?
I see you used zip ties does it work?
Thank you for sharing this!
great! thank you.
Shark doesn’t sell a replacement. I designed one and put it up on eBay for $8 plus shipping. I send two pieces (since it’s easy to break it while installing) and a replacement spring, since those tend to go flying. People seem pretty happy with them.
https://www.ebay.com/itm/124766956799
Makes me mad when companies don’t sell a replacement for small, easily breakable parts on relatively expensive items. Just adds to the landfills.
这个答案有帮助吗?
There is someone on ebay who apparently made the piece and sell them for $8.00 plus shipping. However I also used a wide heavy zip tide and it works perfectly.
这个答案有帮助吗?
Speaking of which, did the part work for you, Major?
The clip without the spring actually worked and held the elbow in place I would use it in combination with a zip tie to insure the elbow seats properly
这个答案有帮助吗?
It’s called a rear hose swivel valve and latch.
Shark does not sell it. Found it used for 40. Knock off for 28. Crazy prices. Have not purchased.
this is the item
这个答案有帮助吗?
I used gorilla tape but am now going to add a zip tie
@kak708 will not buy from shark again if I cannot get parts to fix it, mine broke also I do not like to half ass fix things.
过去 24 小时: 8
过去 7 天: 25
过去 30 天: 100
总计 6,694
13条评论
I have the same problem. Did you find a fix for it?
Thank you,
Geri
由 gmak5491 完成的
I have the same problem. does anyone know where to get one?
由 Katherine Womack 完成的
I used one thicker zip tie and it works beautiful; great tip, thanks so very much!
由 Mike & Brenda Moret 完成的
The zip tie works perfectly! Thanks for the engineering tip!
由 Keith Doran 完成的
Thank You for the Cable Tie/Zip tie tip. It has just happened to us.
由 pattymolaw 完成的
显示更多的8条评论
