跳转到主内容
The Shark Rotator NV502 vacuum was made in 2013, weighs 15.5 pounds, and includes a lift away handle. The vacuum can be used on both carpet and hardwood floors.
17 个问题 查看全部
I need a new elbow clip?
The clip that attaches the elbow to the body of the vacuum and the hose is broken off. I Need a new one and can not find it in the parts lists. Whats it called and am I able to buy a new one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
13条评论
I have the same problem. Did you find a fix for it?
Thank you,
Geri
完成的
I have the same problem. does anyone know where to get one?
完成的
I used one thicker zip tie and it works beautiful; great tip, thanks so very much!
完成的
The zip tie works perfectly! Thanks for the engineering tip!
完成的
Thank You for the Cable Tie/Zip tie tip. It has just happened to us.
完成的
显示更多的8条评论
添加一条评论
7个答案
最有帮助的答案
Same happened to me and I wound up using two zip ties to secure it in place. Works just like normal.
这个答案有帮助吗?
得分 6
3条评论:
I see you used zip ties does it work?
完成的
Thank you for sharing this!
完成的
great! thank you.
完成的
添加一条评论
I found some on eBay for $8. It’s called a lower hose latch on there.
这个答案有帮助吗?
得分 1
添加一条评论
Shark doesn’t sell a replacement. I designed one and put it up on eBay for $8 plus shipping. I send two pieces (since it’s easy to break it while installing) and a replacement spring, since those tend to go flying. People seem pretty happy with them.
https://www.ebay.com/itm/124766956799
Makes me mad when companies don’t sell a replacement for small, easily breakable parts on relatively expensive items. Just adds to the landfills.
这个答案有帮助吗?
得分 1
添加一条评论
There is someone on ebay who apparently made the piece and sell them for $8.00 plus shipping. However I also used a wide heavy zip tide and it works perfectly.
这个答案有帮助吗?
得分 1
1条评论:
Speaking of which, did the part work for you, Major?
完成的
添加一条评论
The clip without the spring actually worked and held the elbow in place I would use it in combination with a zip tie to insure the elbow seats properly
这个答案有帮助吗?
得分 0
添加一条评论
It’s called a rear hose swivel valve and latch.
Shark does not sell it. Found it used for 40. Knock off for 28. Crazy prices. Have not purchased.
Update (01/10/2020)
this is the item
这个答案有帮助吗?
得分 0
2条评论:
I used gorilla tape but am now going to add a zip tie
完成的
@kak708 will not buy from shark again if I cannot get parts to fix it, mine broke also I do not like to half ass fix things.
完成的
添加一条评论
Hose reel swivel spring. Took me days to find out what that part was called
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
julie0000davis 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 25
过去 30 天: 100
总计 6,694
