跳转到主内容
The Shark Rotator NV502 vacuum was made in 2013, weighs 15.5 pounds, and includes a lift away handle. The vacuum can be used on both carpet and hardwood floors.
19 个问题 查看全部
I need a new elbow clip?
The clip that attaches the elbow to the body of the vacuum and the hose is broken off. I Need a new one and can not find it in the parts lists. Whats it called and am I able to buy a new one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
13条评论
I have the same problem. Did you find a fix for it?
Thank you,
Geri
完成的
I have the same problem. does anyone know where to get one?
完成的
I used one thicker zip tie and it works beautiful; great tip, thanks so very much!
完成的
The zip tie works perfectly! Thanks for the engineering tip!
完成的
Thank You for the Cable Tie/Zip tie tip. It has just happened to us.
完成的
显示更多的8条评论
添加一条评论
8个答案
最有帮助的答案
Same happened to me and I wound up using two zip ties to secure it in place. Works just like normal.
这个答案有帮助吗?
得分 6
3条评论:
I see you used zip ties does it work?
完成的
Thank you for sharing this!
完成的
great! thank you.
完成的
添加一条评论
I found some on eBay for $8. It’s called a lower hose latch on there.
这个答案有帮助吗?
得分 2
添加一条评论
Shark doesn’t sell a replacement. I designed one and put it up on eBay for $8 plus shipping. I send two pieces (since it’s easy to break it while installing) and a replacement spring, since those tend to go flying. People seem pretty happy with them.
https://www.ebay.com/itm/124766956799
Makes me mad when companies don’t sell a replacement for small, easily breakable parts on relatively expensive items. Just adds to the landfills.
这个答案有帮助吗?
得分 1
1条评论:
Did you put the zip tie where the spring would go from the red clip?
完成的
添加一条评论
There is someone on ebay who apparently made the piece and sell them for $8.00 plus shipping. However I also used a wide heavy zip tide and it works perfectly.
这个答案有帮助吗?
得分 1
2条评论:
Speaking of which, did the part work for you, Major?
完成的
Hey, did you put the zip tire where the spring went or what did you place?
完成的
添加一条评论
The clip without the spring actually worked and held the elbow in place I would use it in combination with a zip tie to insure the elbow seats properly
这个答案有帮助吗?
得分 0
添加一条评论
It’s called a rear hose swivel valve and latch.
Shark does not sell it. Found it used for 40. Knock off for 28. Crazy prices. Have not purchased.
Update (01/10/2020)
this is the item
这个答案有帮助吗?
得分 0
2条评论:
I used gorilla tape but am now going to add a zip tie
完成的
@kak708 will not buy from shark again if I cannot get parts to fix it, mine broke also I do not like to half ass fix things.
完成的
添加一条评论
Hose reel swivel spring. Took me days to find out what that part was called
这个答案有帮助吗?
得分 0
添加一条评论
So my red clip broke and when I ordered it, I thought I was ordering it. They sent me the whole elbow attachment so as I’m trying to put the new attachment on thinking, I don’t need the clip. I’ve taken the middle spring and the middle piece of the inside of it came off I don’t know how to put it back on ultimately how do I replace the red clip or rig so that it works thank you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
julie0000davis 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 84
总计 7,755
