跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
SSD problems why did it fail and why replacement not working
Have a MacBook Air 2017 with SSD failing 1 month after warranty expired.
Purchased JetDrive 850 but not recognized by my MacBook Air!
Help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi did you fix the problem ?
完成的
添加一条评论
3个答案
最有帮助的答案
Take it into Apple with the original drive put back in it and ask for a “Warranty Exception” from the manager.
But first request the ability to purchase AppleCare Extended Warranty. You were unable to because ………..
这个答案有帮助吗?
得分 1
添加一条评论
Are you able to get into recovery with your original SSD?
What does diagnostics telling you?
Reference: Mac startup key combinations
Does the system boot up from an external drive?
这个答案有帮助吗?
得分 0
添加一条评论
ensure the drive is securely attached and create a bootable USB with OSX on it. On boot hold down the option button until the drive is listed. re install the OS and you should be good. if this does not work the drive may be a dud.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Surya Teja (sth) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 597
