SSD problems why did it fail and why replacement not working
Have a MacBook Air 2017 with SSD failing 1 month after warranty expired.
Purchased JetDrive 850 but not recognized by my MacBook Air!
Help
Take it into Apple with the original drive put back in it and ask for a “Warranty Exception” from the manager.
But first request the ability to purchase AppleCare Extended Warranty. You were unable to because ………..
这个答案有帮助吗?
Are you able to get into recovery with your original SSD?
What does diagnostics telling you?
Reference: Mac startup key combinations
Does the system boot up from an external drive?
这个答案有帮助吗?
ensure the drive is securely attached and create a bootable USB with OSX on it. On boot hold down the option button until the drive is listed. re install the OS and you should be good. if this does not work the drive may be a dud.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 570
Hi did you fix the problem ?
由 Jordan Bekouet 完成的
