跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Error 3194
i have iphone 3gs and i have been follow your guide lines but,... now my iphone stuc on recovery mode and my itunes has message stop working and error 3194.
please help..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Please start a new question so that others will see it. This is an old answered question and very few will even look at an answered question.
完成的
mahendra, check this question Cant restore iPhone stuck on error 3194 and see what Brad is saying. Probably your best bet. here is part of the explanation "Lots user who were downgrade iOS 4 to 3.1.3 have been facing a iPhone Restore Error Code 3194 which occurs when users try to restore to iOS 3.1.3 firmware from iOS4. But what is this error all about? Well, Apple always signs the latest firmware not the prior one and while downgrading to previous firmware the 3194 error will come if you have not saved or taken backup of ECID SHSH blobs of previous firmware.
Details: http://thetechjournal.com/electronics/ip...
完成的
ITsyndicate Server Management Services | Azure DevOps | Support & Maintenance.
Website and Server Monitoring – Monitor applications and web service. Stop worrying about server downtime, security and monitoring. Get on-board with our server management services and let us handle your servers. Top DevOps Services Company! Itsyndicate.org
marketing-stars.ml primeparts.pro
完成的
For the past decade, our dedicated DevOps teams have accumulated impressive expertise in uniting development and operations using such advanced DevOps technologies as Gradle, Jit, Jenkins, Bamboo, etc. DevOps services we provide allow businesses enjoying the stability of operating environments, cutting the development time, and getting faster feature delivery. DevOps Services Company - https://itsyndicate.org/services/devops-... and https://itsyndicate.org/blog/devops-cons....
完成的
添加一条评论
2个答案
已选择的解决方案
Error 3194 is usually because SHSH were not available to iTunes during the restore. But if you are at Recovery Mode you can always try program TinyUmbrella to allow it to try Exit Recovery button. If that does not work. Then you must restore and allow SHSH to be used. If you are going with stock firmware 4.3.3 then you can allow iTunes to do everything for you. But you must make sure you are not blocking Apple from signing the firmware with Apple SHSH. Therefore use TinyUmbrella program, go to "Advanced" and make sure there is "no check mark" in the box "set hosts to Cydia on exit". Again no check in the box. If you don't want to use TinyUmbrella, then search for your computer Hosts file and make sure there are no lines with numbers and gs.apple.com (this is the blocking Apple line), delete these lines entirely. If your Hosts file is clean then let iTunes restore for you. If you have iPad baseband then you will need to restore with Custom Firmware, Pwned DFU and possibly help from TinyUmbrella.
这个答案有帮助吗?
得分 1
添加一条评论
I wrote a short guide that explains how to fix error 3194:
http://blackbox-iphone.com/index.php/how...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mahendra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 10,952
