跳转到主内容
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
202 个问题 查看全部
Every fan inside is spinning at high speed
Hello @mayer
I have a Mac Pro 5,1 (mid 2010) and I have months this problem with the fan’s spinning all the way to the max sounding really loud and annoying after a while.
I saw your screenshot from your fan speed’s and compared it with mine.
I checked inside my Mac Pro and every fan inside is spinning at high speed, but the fans that control my: Intake, Exhaust and PS are at 0? But they are spinning inside and with no issue.
The fan’s did have a little bit of dust but I already blew it away with an electric blower, and nothing changed after blowing away the dust.
Hope for some good tips!
Thanks in advance
Update (02/04/2019)
@mayer @danj
The fans of the Boost A Boost B is now at maximum speed in TG Speed control. The mac is just turned on and there is no task running.
I did not do anything from yesterday on, this just happened after booting it up from yesterday
Update (02/04/2019)
@danj
I ran the’ Quick Test’ and found one error.
4MOT/1/40000003 : PCI - 922
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
11条评论
It now looks like the CPU sensors have a problem which is why your fan's are maxing out. Check the CPU carrier contacts.
完成的
i restarted the system and checked for the connector and it looks al good.
The fans are now again at low speed like on the first picture at my initial post, but the fans are still going at full speed.
is it normal that there are 3 fans showing speed at 0 (intake,exhaust and ps)
You mentioned the mac pro diagnostics, how can i run the test?
i already tried with the original graphic card pressing 'D' at the startup but it stays a long time white screen and after it just boots up normally
thanks
完成的
Review this: How to Start up your Mac in Apple Diagnostics or Hardware Test Mode
The carrier unit like has a bad connection so as the system heats up it looses its connection.
完成的
@danj
i already tried it pressing the D key but nothing happend, it just booted up to mac os after a couple minutes and denied to go to diagnostics. is this normal ?
i used a Usb keyboard.
完成的
Then you need to run from the grey OS installer disk that came with the system as outlined.
完成的
显示更多的6条评论
添加一条评论
3个答案
最有帮助的答案
I felt you needed your own question on this. I’m posting my previous answer from the other question. I will need some time to research your issue further, will get back to you.
What upgrades or repairs have you done on this machine, what OS X are you running?
I’d run TG Pro to see if I could isolate the problem:
https://www.tunabellysoftware.com/tgpro/
compare mine that’s been running all day with yours
Please note yours is showing a hard drive sensor failure. I’d pull one drive at a time and restart to find the offending one.
Your CPU’s are also running much hotter than mine.
I’m running 2x 2.93 GHz Quad-Core Intel Xeon
Dos-Dude flashed 2009 to 5,1 running Sierra
UPDATE
2671
Single-Core Score
15113
Multi-Core Score
Geekbench 4.3.3 for Mac OS X x86 (64-bit)
System Information
System InformationOperating SystemmacOS 10.12.6 (Build 16G1710)ModelMacPro5,1Model IDMacPro5,1MotherboardApple Inc. Mac-F221BEC8 Memory12.0 GB 1066 MHz DDR3
这个答案有帮助吗?
得分 1
5条评论:
Yes thats right to open a new question.
Thanks for the reply!
完成的
完成的
The fan's problem spinning at max already existed even before i upgraded the cpu's and upgraded graphics card.
I run Mac Os Sierra 10.12.6
Upgraded original 5.1 Mac Pro from 2 quad core's to 2 six core's. I have posted a screenshot above with specs of my system. If u need more info let me know. Thanks
完成的
Well TG Pro is not showing your fans as running fast, let's ask @danj as he has more experience that I do using TGP.
完成的
@mayer - TG Pro looks good in Aldo's post, your's looks like there is a problem. In any case TG Pro doesn't capture the other sensors SMC accesses. I'm wondering what Apple Mac Pro diagnostics shows.
完成的
添加一条评论
AHD - 4MOT/1/40000003 : PCI - 922
The key is the PCI entry. Remove slowly the PCI boards sans the Video board. After removing each did you encounter a more stable system?
这个答案有帮助吗?
得分 0
6条评论:
What do you mean exactly?
I only have the Graphics Card installed on the motherboard and other PCIE slots are empty.
完成的
Then you'll need to move the card to another slot to see what happens.
完成的
Alright i will test this later and let you know. Thanks!
完成的
I tried like u told me,
changed the Graphics Card from one to the other PCI but nothing changed, The fans still running high. ( even tried with all empty slots and the same problem )
完成的
Then the logic board has a bad solder joint as your system should not be jumping between working and not working.
完成的
显示更多的1条评论
添加一条评论
The problem in the ( fan motor or his cable ) , the power line of lower speed doesn’t work , so it just run in higher speed to stop damaging your cpu.
这个答案有帮助吗?
得分 0
1条评论:
But how can i know wich fan is not working properly?
完成的
添加一条评论
添加你的答案
Aldo B 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 26
总计 3,299
