跳转到主内容
加入维修社区 - 创建账户
Xiaomi Mi A2(全球范围内也称为 Mi 6X)由小米于 2018 年 7 月发布,提供多种内存配置。它属于 Android One 项目,该项目保证提供两年的更新支持。
Backlight only works during startup
I recently changed the screen on a Xiaomi Mi A2 Lite. When I start the phone up, the Android One logo displays with full brightness and colour without any issues.
The problem is that once the phone turns on there is no backlight. You can still see the display if you are in a dark room and everything seems to show correctly. I have tried updating and factory resetting but still having the same problem.
Any advice would be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Did you ever find an answer to this issue? My phone developed the same problem yesterday.
由完成的
I have the same problem with a replacement screen. Did you find any solution?
由完成的
Have you found what was causing this?
I’ve the same issue, replaced the lcd on a xiaomi mi a1 and the backlight is present at the logo startup but completely black after that.
On a dark room I can barely see the screen and all it’s working, but adaptive light button is missing, seems like the bootloader is able to use the backlight but not android itself
由完成的
添加一条评论
1个答案
I’d try to disable the “adaptive brightness” feature under settings->display, but I highly doubt that this can solve an issue like this.
On the software side there should be restrictions in place to how dim the screen can get and I’ve never even heard of the software having the permission to turn the backlight off.
The only suggestion then would be to replace the screen, but since the backlight is working upon boot…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan Storey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,361
