The Motor has stopped
The motor seems to have stopped and it's over heating. How do I troubleshoot this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @rlh781 ,
Does the motor restart after it has cooled down?
Does the fridge ever reach the set temperature so that the compressor can switch off or is it running all the time? (check first thing in the a.m. as the fridge has had all night to get to the set temps without the door being opened and the cold air being let out (or the warmer air in, whichever you like)
if it never reaches the set temps and the compressor is running all the time trying to drive down the temp can you hear if the evaporator fan is running. It is behind a panel in the fridge and will stop when the door is opened and start again when the door is shut. You may have to place an ear against the fridge to hear it stop and start when you open and close the door.
由完成的
添加一条评论
