跳转到主内容
加入维修社区 - 创建账户
• 输入接口:iPod™ 底座接口 / 3.5mm 立体声插孔 • 扬声器:2x Ridge TM 高/中音单元和 2x Atlas TM 低音单元 • 功放功率:2x15 瓦高/中音,2x30 瓦低音 • 频率响应:40Hz – 20kHz • 输入阻抗:>10kOhm • 电源:8x D 型电池/充电电池,电源适配器 • 尺寸(长x宽x高):500mm x 230mm x 240mm
How to replace broken speaker
How can I replace the speakers?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If you can get into the device it should be as simple as de-soldering the two wires connecting the speakers to the main board. Then you would need to get a replacement speaker of the same size and power as the one already in the device which may or may not be a propriety size speaker.
The hard part would most likely be figuring out how to open the speaker which I cannot help with since I don’t own one and have never worked on one. This procedure is just how I have changed speakers in multiple different PC speakers or iHome type devices.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
abelplus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 55
总计 3,501
