跳转到主内容
加入维修社区 - 创建账户
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
Replacing GPU thermal paste
Is it possible to replace the paste on the GPU on the iMac Intel 17" Core Duo from early 2006? Or is it a thermal heat pad?
My GPU diode runs at around 53C idle, about 65C load, but I'd like it lower if possible.
Is the GPU heatsink the sort of rectangular shaped one with four black pegs on the top side of the motherboard underneath the display?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Yes, you can replace the paste, there is no pad. The logic board must be removed. You can also upgrade your processor to a Core 2 Duo 1.83 or 2.16 GHz to be able to use Lion OS next month. See this answer for more info" Core Duo CPU upgrade to Core 2 Duo CPU?
Heres how to get to it: iMac Intel 17" Logic Board Replacement
这个答案有帮助吗?
得分 2
添加一条评论
I don't think the heat-sink you speak of is the GPU. Suspect it is the North-bridge (or Mac equivalent)
THIS GUIDE will give the general idea on the thermal paste application.
Not sure about the location of the GPU on this board though. Mayer will probably know.
HIH
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joshua C 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 2,373
