跳转到主内容
加入维修社区 - 创建账户
这款打印机与 C4780 类似。 它缺少(有时容易发生故障的)无线联网硬件,只能通过有线方式进行网络打印。
paper will not pick up from stack
Paper in stack will not feed and says to” load paper “
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This can be caused by dirty paper pick up rollers or a broken paper present sensor. Remove all the paper in the tray and look at the paper pickup rollers to check for bits of paper, you can clean the rollers with rubbing alcohol or alcohol prep wipes. The paper present sensor should be near the paper pickup roller, look for a thin black piece of plastic and verify that it is not out of position and moves freely.
这个答案有帮助吗?
得分 1
1条评论:
Need picture!
完成的
添加一条评论
添加你的答案
jcl4arch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 471
