跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone X memory upgrade?
Hi, so I’m going to replace the logic board on an IC locked phone and was curious if I could put a 256gb one inside. It’s currently a 64gb
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Anyone else have any ideas? I wanna make sure
完成的
添加一条评论
3个答案
已选择的解决方案
I agree with Tom. It is, technically possible, to upgrade the memory on an iPhone X. Whether or not it is cost effective really depends on where you are in the world. The actual memory chip is quite expensive and it requires that you have access to a special programmer, such as this one. Additionally, there is quite a bit of skill required (and lots of specialized tools) to do this upgrade successfully. If it goes sideways, you will kill the logic board. Replacing the logic board is easier but certainly not inexpensive either.
So if you are in Asia, then you can probably have this done affordably. If you are in the US, then the cost will be significant.
这个答案有帮助吗?
得分 4
3条评论:
Is replacing the logic board as simple as just swapping them out? And also out of curiosity would I be able to buy a 64gb logic board then if I wanted to later on just buy a memory chip to upgrade the memory on the logic board? You guys are being very helpful I appreciate it!
完成的
And also what problems would you meet if you bought a 256gb board I’m assuming with the chip already on it and just put it into the iPhone, technically would that be the same thing as flashing the chip to match the serial number of the previous board?
完成的
You should re-read my answer. I detail that upgrading the memory is both expensive and difficult. This isn't a microSD card ;>). The logic board is the phone...if you swap boards, you essentially have a new phone.
完成的
添加一条评论
It is possible after you reprogram several serial numbers on the flash memory chip.
这个答案有帮助吗?
得分 2
6条评论:
So that’s the only way? The memory chip isn’t apart of the mother board?
完成的
If I’m replacing a 64gb with a 64gb it won’t require any flashing, correct?
完成的
You need to flash the chip every time, the chip is personalized to each board.
完成的
That would make sense but why aren’t any guides telling you, you need to flash the chip before putting in a new board?
完成的
If you put the entire logic board and home button then it isnt needed to program the chip. you can swap it easy no troubles.
完成的
显示更多的1条评论
添加一条评论
How To Upgrade iPhone X 64GB Storage To 256GB
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Connor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 3,588
