简介
REWA LAB has been constantly working on mobile phone repair solutions. Whether it is as simple as broken screen replacement or as complicated as chip-level motherboard repair. With the development of science and technology, mobile phone repair solutions are also constantly improving. Today we will show you how to upgrade the storage of iPhone X from 64GB to 256GB with the help of iRepair DFU Box instead of traditional NAND chip programmers.
视频概述
We need to back up the underlying data of the original 64GB NAND first. We will use iRepair DFU Box today to back up the data without removing the NAND flash chip.
Connect iRepair DFU Box to the computer. Then connect the phone with iRepair DFU Box. Put the phone into DFU mode.
Click ‘DFU Model’. The phone will enter into purple mode. Continue to click ‘Query Info’ to check the underlying data.
Then click ‘back up SYSCFG’ to back up the underlying data. Once done, click ‘Exit recovery mode, Exit diagnosis’.
Disconnect the phone. The phone will turn on automatically.
Disconnect the battery and remove the display assembly. Take out the motherboard. Attach the motherboard to the PCB Holder.
Stick high-temperature tape on components around NAND. Remove black adhesive around NAND with Hot Air Gun. Once done, keep the nozzle close to the NAND and heat with Hot Air Gun for about 30s.
Pry up the NAND flash chip carefully. Then clean the bonding pad carefully.
Place the brand new 256GB NAND on the repair platform. Get the BGA Reballing Stencil in position. Smear medium-temp solder paste evenly on the stencil.
Heat with Hot Air Gun so that all solder balls can shape up completely. Once completed, wait for 1 minute.
Then separate the NAND flash chip from the stencil. Heat again to ensure the formation of solder balls.
Apply some BGA paste flux to the bonding pad. Get the 256GB NAND in the right position. Solder with Hot Air Gun.
Get the motherboard installed and display assembly connected. Connect the battery.
Connect the phone with computer. Restore the phone with the help of 3U Tools. Once finished, the phone turns on automatically.
Click ‘DFU Model’. The phone will enter into purple mode. Continue to click ‘Restore Data’.
Write the underlying data stored in the computer to the 256GB NAND. Once done, click ‘Query Info’ to check the underlying data.
Once finished, click ‘Exit recovery mode, Exit diagnosis’.
- How to Upgrade iPhone 6S 16GB Storage to 128GB
- How to Upgrade iPhone 7 Plus Storage/Memory To 256 GB
- How to Restore A Badly Damaged iPhone X
- iPhone 11 Pro Max Cracked Screen Repair - Glass Only
- iPhone X Broken Screen Glass-Only Repair
- How to Fix Samsung S7 edge Won't Turn on - Logic Board Solution
- iPhone 7 Plus Cracked Screen Glass Only Repair
- 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above
- iPhone 11 Series Non-Genuine Screen Warning/Important Display Message - 100% Fix
2等其他人完成本指南。
