跳转到主内容
加入维修社区 - 创建账户
Braun 剃须刀维修指南。
Razor not turn on
Cruzer5 charges but does not turn on
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi @tamandy239 ,
Does it turn on when the charger is connected and switched on?
If it does then the batteries may be failing to hold their charge and need to be replaced.
If it doesn’t then there may be a problem with the on/off switch etc.
In any event the razor will need to be opened and inspected as to what the problem may be.
Here’s a link to a video that shows how to dis-assemble the razor.
Hopefully this is of some help.
这个答案有帮助吗?
得分 3
2条评论:
The video is private, I can't view it.
由完成的
@ハッサンモハメド
Try this one
由完成的
添加一条评论
Make sure the razor is charging correctly. It is a common mistake to see the solid green light on the charger, but it also requires the flashing green light on the razor itself.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andy 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 32
过去 30 天: 97
总计 23,128
