Broken Bluetooth WiFi antenna
What part do I order to replace the Bluetooth WiFi antenna?
Both the Bluetooth and WiFi antennas are located within the lids clutch cover.
You’ll need to remove the lid to get to them MacBook Air 13" Mid 2012 Display Assembly Replacement and here’s the needed part MacBook Air 13" Hinge/Clutch LH - iSight/antenna cables
这个答案有帮助吗?
Are you sure it is the antenna because it got smashed by a hit or is it just that Wifi/Bt don’t work ? It might as well be the card gone bad:
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 354
2条评论
Check for viruses before ordering parts.
由 mayer 完成的
That’s been done. Need the part specs. Anyone?
由 Melissa 完成的
