跳转到主内容
加入维修社区 - 创建账户
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
iMac won't power on after re adhering screen.
A week ago I replaced my HD with an SSD and everything was working great. At the time I had purchased some double sided tape but it seemed too thick so I didn’t use it and just taped the screen on the corners until the new tape arrived. I removed the screen following a video from here as a guide and carefully removed and replaced the adhesive. When it was all sealed up I got nothing. No sound, no chime, fan or anything else. I proceeded to go through the task of taking the screen off to see if I stupidly didn’t connect to two cables from the screen but they were there. Upon reading about the diagnostics lights I see that I am getting LED 1 which indicates there is power to the board but that’s as far as it goes. Please Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
No. All LED #1 means is that you are getting trickle power to the power supply. It does not mean that it is giving power to anything else. So that’s your starting point.
这个答案有帮助吗?
得分 1
2条评论:
Where do I go from there? I am baffled that it doesn’t turn on because it was working great and all I did was remove and add tape. Nothing was touched or tampered with at all.
完成的
Use a multimeter and start testing that power supply.
完成的
添加一条评论
添加你的答案
Jerry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 96
