跳转到主内容
加入维修社区 - 创建账户
这是一款适用于移动设备和平板电脑的蓝牙扬声器,可以为配对的设备拨打电话。于 2014 年秋季发布。
Running very slow. IC damaged
I have jbl charge 2 and it went very slow
Like music is very slow i mean sound is high volume but very slow
Shopkeeper saus that IC is damaged
What shoul i do and how to buy IC ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Not sure which IC the shopkeeper was referring to.
There are a few ICs on the motherboard, e.g. the WiFi IC , the audio amplifier IC, the power IC etc.
Try connecting the speaker to an audio source e.g mobile phone - plug into headphone jack, via an appropriate 3.5mm stereo audio cable - example only and check the quality of the audio from the speaker.
This will prove if the problem is with the BT section of the speaker or not.
How old is the speaker?
If you have had it since new, check the manufacturer's warranty for the speaker to see how long it is. If you haven't got the warranty information anymore, go online and search for JBL Charge 2 warranty for your location.
If your speaker is still within the manufacturer's warranty period, follow the directions as to what you have to do to make a claim for a manufacturer's warranty repair or replacement.
这个答案有帮助吗?
得分 1
1条评论:
Depending on the system you are using with your JBL speaker via Bluetooth you may need updated drivers for your JBL speaker and/or the OS of the computer you are using.
由完成的
添加一条评论
添加你的答案
Bharnawa Records 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 24
总计 640
