跳转到主内容
加入维修社区 - 创建账户
多功能彩色打印机及扫描仪(USB 2.0) 兼容运行 Windows 的 PC 以及运行 OS-X 和 MacOS 的 Mac 系统
The printer is not printing
The printer is not working even when there are both cartridges.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hi,
Can you copy a document using the printer's control panel?
Are there any error lights showing on the printer's control panel display?
What have you tried?
由完成的
u can scan but not print
由完成的
添加一条评论
1个答案
已选择的解决方案
METHOD1: UPDATE DRIVERS
Step1: Press start button and select control panel option.
Step2: Open device manager and search network adapters.
Step3: Select the mode to which printer is connected Ethernet or Wi-Fi.
Step4: Check driver for updates and check if the driver is running successfully.
Step5: If not running disable the driver and enable it again.
METHOD2: SOFT RESET PRINTER
Step1: Switch of the printer and disconnect all the cables.
Step2: Press and hold power button for approximately 60 seconds.
Step3: Restart the printer and check the error is fixed.
METHOD3: SEMI RESET PRINTER
Step1: If on opening the printer door there is no paper stuck in the printer go to step2 or if found remove the paper carefully and restart the printer.
Step2: Press home button and navigate using keys to support menu.
Step3: Enter support menu and you found support x where x will be model number.
Step4: Now press > button till you find resets menu and press ok button.
Step5: Now country and language reset occurs press right button.
Step6: Press right button on partial reset to reach semi-full reset prompt and press ok button. or contact hp support
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shreyas kini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 39
总计 4,347
