跳转到主内容
New power cord not charging new MacBook Air battery
Hi folks.
I bought a new battery through iFixit and installed it, and also bought a new MagSafe charger. Both have worked great for about a month.
Today the battery was at 40% when I plugged it in. The MagSafe cord light didn’t come on at all (no Amber, no Green), however the screen lit up a bit and the battery icon in the upper right has the lightening bolt through it that indicates it is charging. However, it is definitely not charging, and when I click on the battery icon, it says, “Battery Is Not Charging.”
I did a SMC reset, which didn’t help. It says the battery condition is normal. I had it unplugged for a bit and it fell to 39%, however it is holding there with the charger plugged in.
I am wondering if the iFixit battery has failed…
Any help appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
If you can install CoconutBattery and take a snapshot of the main window and post it here for us to see 在已经存在的问题里加入图片 Do one with the MagSafe charger connected and a second with it disconnected.
完成的
@bartolome - Did you get CoconutBattery installed and take the snapshots? Please post them so we can move forward here.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi Erin,
It somewhat sounds like the charger isn't supplying enough current to power the laptop and the battery. If you have access to a different charger, I would suggest trying that first…even if it means stopping by your local Apple store and plugging it in there!
这个答案有帮助吗?
得分 1
1条评论:
I tried my roomate's certified apple charger and it's the same problem.
完成的
添加一条评论
I would check the systems MagSafe connector for damage (melted) are the contacts shiny and clean? Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters Do make sure you’ve got a real Apple charger and the correct one for your system.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Erin Campbell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 122
