跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
911 个问题 查看全部
Screen cracked, where can I purchase another one?
The screen cracked on my 47" Vizio LCD 1080p. I was wondering if there was a place where I could get another LCD panel to replace it myself. I live in Ohio. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 74
105条评论
Dustin can you post the serial and model numbers as well? It MAY help to find what you are looking for.
完成的
The model number is VL470M. I bought the tv from a yard sale and the serial number was colored over with a permanent marker. I suppose so no one could use the original owners warranty information. Thanks
完成的
Well im triying to fine some were on the internet were i can bug the screen panel for my 55 inch LG tv any idea ??
完成的
Usually when a serial number is blacked out it is because it has been refurbished. If it is blacked out by use of a black marker, you can go over the marker with a dry erase marker and wipe quickly to remove the permanent marker.
完成的
I got a 32" vizio I need a screen
完成的
显示更多的100条评论
添加一条评论
3个答案
已选择的解决方案
Dustin, Michale Ku is about right with the price. First off, you can get a field tech service manual from here. Your panel part number is LC470WUH-SBR1 and it is available at this place for $358.12. Replacement cost for the TV is about $800, so it's strictly a matter of economics. I'd do it since it would save me some money. I hope this helps, good luck.
这个答案有帮助吗?
得分 7
21条评论:
Thank you so much I will keep you posted on my progress
完成的
no help at all
完成的
lloyd Lance how do you figure? What is your question since you feel that my answer is no help to you?
完成的
What about sharp tvs my daughter hit mine with a plastic bat and cracked the screen any in please
完成的
Donovan Burton depends on the model and size. LCD panels can be tricky and expensive to come by.
完成的
显示更多的16条评论
添加一条评论
if it's broken, you are better off getting a new TV. The panel will run about $300-400.
这个答案有帮助吗?
得分 5
11条评论:
I have a 70" vizio smart 3D TV what would a new screen cost me an were can I get one The TV is new never been used got it with a good 65" for $500 so I think its worth fixing
完成的
I have a Vizio 60-inch TV screen cracked for sale
完成的
What your price
完成的
I have 43 inch visio 2 months old cracked screen model #D34n-E4
完成的
I have A 55 inch vizio smart tv cracked screen for sale asking.$150..The tv is 1yrs old and was not being used much..
完成的
显示更多的6条评论
添加一条评论
Your best bet would be to go to liquidation.com purchase a lot for around 300 which will have anywhere from 4-8 tvs they will have a manifest with what brand and sizes each tv is. Hope the one that matches yours has a working screen as many of them do. The other ones can be sold for parts and usually around 100-200% profit
这个答案有帮助吗?
得分 1
3条评论:
My internal screen is cracked and is displaying multi color ligns on my visio E422VA. Checked on sears.com, Visio site, and a bunch of others and can't find a screen for it . Where can I find one for as cheap as possible?
完成的
The screen of my LG 70 inches TV uhd got cracked; how can I replace it?
完成的
I have a 75 inch v series vizio can't find screen for it. I'm in Missouri. Can anyone help me have not had it for a year.
完成的
添加一条评论
添加你的答案
Dustin 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 89
总计 319,864
