跳转到主内容
加入维修社区 - 创建账户
Omaker 出品的便携式蓝牙 4.0 扬声器。该扬声器具备 IP54 抗水等级,专为户外和严苛环境使用而设计。拥有 12 小时的电池续航时间,经久耐用。
How do I replace the speaker?
I am afraid I have blown the speaker as the glue surrounding the mid-piece of the speaker has been decayed likely through overuse. Where may I get a new speaker and how may I replace it? Is this worth the trouble and finances required?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here’s a link to the ifixit Omaker M4 主板更换 guide.
It is useful as it shows how to open the speaker case so that you can get to the speaker driver.
I cannot find an Omaker replacement for the speaker, but looking at the images in the guide, the information stamped on the speaker shows that it is a 4 Ohm 3 Watt speaker.
If you remove the speaker from its mounts in the case and measure its’ diameter you can use this information in conjunction with the above power specifications to get a suitable replacement.
Here’s a link to just one supplier of 4 Ohm 3 Watt speakers, showing speakers with varying diameters, hopefully one of which will fit inside the case.
You may find other suppliers that suit you better. Just search for (insert diameter of speaker) 4 Ohm 3W speaker to get results
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Gavin 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 21
总计 466
