跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1200 个问题 查看全部
Is there a way to get the cover pushed down?
I noticed that the previous times the phone was opened the 3 tabs at the top of my iphone X got very loose, in fact when i was closing it, two of them just snapped off! So now the top part of my iphone is super loose when closing the screen after opening it up. Is there an easy way to get the top part to stay completely closed? Was thinking about trying to reweld the tabs back on….
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Other than an adhesive, not really. If using adhesive, you want to be careful to make sure it isn’t covering any important sensors. Welding the tabs on can be difficult, as you will need to get the exact size of the tabs proper.
这个答案有帮助吗?
得分 0
2条评论:
I have the original tabs still. They just kinda snapped off.
完成的
Maybe try epoxy to set them back on.
完成的
添加一条评论
添加你的答案
michael stevens 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 52
