跳转到主内容
加入维修社区 - 创建账户
焊接是一种通过熔化中间的填充金属将两块金属连接在一起的方法。焊接种类繁多,但本文旨在向你介绍电子焊接的基础知识。
Micro soldering start up
Hey all I am hoping there is someone out there who may be able to help me.
Recently I have been doing some research into micro soldering and would like to give it ago.
What equipment should i look at getting and what do I need to take into account.
Any advice would be great .
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Jessa Jones created a set of vids with IFIXIT a few years ago which are very informative! Here’s the first in the series Microsoldering with Jessa Jones.
Theres a lot to it! Between getting the correct gear, you need the skills to read and understand schematics and lastly access to the needed SMT components.
And lastly practice! Lots of it!
这个答案有帮助吗?
得分 4
2条评论:
Thank you very much for this very appreciated.
完成的
Yea .... Dan hit the correct word.... practice made perfect :D
完成的
添加一条评论
Hi claytonrablin
As for me, I had a Hot air SMD rework station and a temperature controlled soldering station.
Some would say for temperature controlled station, minimum 60W and above.
I prefer those stations to be separated, in event of a failure which will brick all usage. Encountered once when my temperature controlled soldering station heating element is bad. Lucky having the hot air, which is needed to solder the new heating element to the soldering iron.
Get good flux, desoldering pumps, etc.
A good start.. .Louis Rossmann videos...
https://www.youtube.com/watch?v=bVoBZqlv...
Update (01/20/2019)
Thankyou very much for this fantastic advice. What did you start off soldering ?
Update (01/20/2019)
Hi claytonrablin
Replacing QFP ethernet chip
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
claytonrablin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 20
总计 731
