Back glass removal advice
Hi all
In need of the back glass cover on a iphone 8 replacing, is it worth just replacing the whole back housing that comes complete with back glass cover, as I have seen it is a nightmare to remove just the glass.
its easier for a diy project to replace the whole casing but its very doable to replace just the glass.
remove everything out of the phone, heat it to between 250-300 degC and use an isessamo to scrape the glass out.
这个答案有帮助吗?
Hi Chis, I am trying to replace the positioning ring on the iphone 8, do you know how to install it when it has no adhesive?
You can just change only back glass with laser back glass removal machine
The laser machine will damage the glue between glass and frame, then its easy to remove the glass.
And you also can buy back glass with bigger camera hole, then no need to remove original camera frame.
这个答案有帮助吗?
Thank you for contributing to the Answers Forum. However, the site owners don't want folks linking/advertising their products/services directly in answers or comments. It is advised that you put your contact and business offerings in your profile and link people back to it.
The moderators thank you!
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 856
1条评论
Found that if not in a rush to remove the broken back glass is to leave it in a sealed container of Isopropyl for about two weeks which acts like a adhesive remover, glass came away a lot easier with this method.
由 colin 完成的
