跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
I just replaced the WiFi module of the iPhoneX but still poor
Hello everyone. I just replaced the Wifi & bluetooth module (one piece). However both of these components are still causing issues. I’m getting absolutely dreadful signal for wifi+bluetooth where I can’t discover anything past 2 feet.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Hi, it sounds like damage to the part of the chip on the Logic Board, caused during the original disassembly of the wifi module. You can try replacing the module you bought to rule out a faulty part, but repair of the chip might involve skilled micro-soldering.
这个答案有帮助吗?
得分 0
添加一条评论
UPDATE: i found the culprit. it seems the connector between wifi ribbon cable + logic board is not staying properly. is there a way to keep the connector down and snapped in? right now im trying to tape it down with electrical tape and RTV to mold over it so when the case is pushed down it will stay down but to no avail currently.
这个答案有帮助吗?
得分 0
添加一条评论
the center latch part of the wifi connector on the logic board was snapped off or removed or something when it was last repaired ( bought this phone used). i kind of have it taped down, but i am getting a weird reboot loop every few minutes now. I tried a hard shutdown/start, and also did a factory reset - tried setting to dec 1, 2017 etc. nothing works. it does a weird reboot loop, i had it on all night and then tried using it and it decided to start rebooting.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michael stevens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 106
